Hello experts,
I faced a little bit problem. I installed Plant Vs Zombies.
But after successful installation of the much loved game Plant Vs Zombies, I got the following System error:
Bass_ChannelPlay function not found in bass.dll.
Please help me to solve this problem.
Bass_ChannelPlay function not found in bass.dll Plant VS Zoombies
Hello Jennifer,
Even after you successfully install the Plant vs Zombies game, players have mentioned about the following system error “Bass_ChannelPlay function not found in bass.dll”. This caused due to loading the wrong version of the bass.dll file when the game loads and this is possible only when you have more than one version of the bass.dll file on your system.
Please follow the below mentioned steps to solve the issue:
Search your windows drive {generally C drive} to find all the bass.dll files.
Delete all other instances of the bass.dll from except for one present in the plant vs zombies game installation folder.
Now should start the game without any error.
Hope this helps!
