Hello friends,
I am experiencing an error when I was trying to install Batman Arkham Asylum. No matter what I do, I simply cant install the game. The screenshot of the error is as follows:
Feature DefaultFeature
Component: DLS_RootDivGame_16
File D:data3.cab
Error Data error (cyclic redundancy check)
OK
Has anyone else encountered such a problem? please help me out. I really want to play this game.
Waiting for your suggestions
Regards
mike
Batman Arkham feature transfer installation error
One of the components used for installing the game is corrupted or invalid. If you have downloaded the game you need to download and installing it again or if you are installing from a cd, check if the cd is in a good working condition with no scratches on the surface of the cd.
To install Batman Arkham Asylum without any errors, follow the below steps.
1. Search for the following files in the Batman Arkham Asylum installation folder.
FirewallInstallHelper.dll
GameuxInstallHelper.dll
EULA.dll
2. Copy the above files to Windowssystem32
3. Now, Go to: Program Files (x86)InstallShield Installation Information and delete all the available files.
4. Now you can install your game without any errors
Thank you.
Hallo Mike,
Are you installing the game from a CD or did you download it from the internet. If you are installing it from a CD there is a high chance that the CD is corrupted. You will therefore need to try cleaning the CD, and then after that retry the installation.
If you downloaded the setup from the internet, the application could be corrupt, and therefore you will need to download it from a trusted site.
Nicke
