Battery alarm gadget sidebar for Windows 7
Asked By 140 points N/A Posted on -
I'm looking for a battery alarm gadget sidebar for my laptop.  I have a Dell XPS 17 and Windows OS 7 64 bit.  I want the alarm that can be customizable with mp3s and visual blinking screen.  Any suggestions?  Thank you.
Best Answer by Donald G Gibbons
Answered By 0 points N/A #180141
Download the Alarm Clock for Windows 7 from the link below:
http://www.julien-manici.com/comments/?id=3
It has an animated visuals when the alarm functions. You can even choose the sounds that you want to play.
Answered By 20 points N/A #180142
The image below is one good example of what you are looking for.
You can download the gadget on this website.
This gadget will monitor the battery life of your laptop and it will alert you once power is getting low. You can also customize the sound or music you want to use as an alarm. It is easily downloadable and free.
Most importantly, you can also customize on how many times you will be notified.
Donald
