Battery Economy Program/Software for Laptops is required
Hi Experts,
I have heard about Battery Economy Program from my colleagues. It somehow consumes laptop’s battery wisely and saves the extra consumption of the battery. I have tried a lot but didn’t find anything. Can anyone help me find any such software for Windows 7
Best Answer by Garrison Roger
Answered By 0 points N/A #167954
I'm afraid that there is no such program or any device available in the market that can enhance your laptop's battery life or consume less. However I have got something which might help you out in the future. The research is focused on low cost synthesis production method lithium ion cathode material for rechargeable batteries are now available for license or assignation. These methods will produce cathode material. It has great features:
Up to 50 % or energy than existing option
30%cheaper than cobalt oxide and on a par with iron phosphate
Safer than existing product due to less heat being generated when in use
Thanks
Answered By 0 points N/A #167955
Hello!
I am sure about the matter. It is not possible to increase your battery power by any software. But you can consume your battery power in Windows 7 by following these procedures:
In Windows 7 you can set up a sleep mode particularly.
After opening your Windows press Windows Key. Write down power options in start search text box.
When you see a result for power options in control panel, and then select it.
A new window will be appeared where you will see three power plans. These are Balanced, Power saver and High performance.
Regards
Shifflett Laurel
