Battery information needed-lenevo laptop urgent
I have a Lenovo G460 laptop with core i3 processor and 2 GB RAM. Recently its battery has gone down so I need to purchase a new battery for my laptop. I need to is there various battery options for one particular laptop.
If there is than I like to know the long lasting one for my laptop.
Kindly someone instruct as soon as possible.
Ariel Chu
Answered By 20 points N/A #109671
Hey Ariel chu!
There are many batteries for any model of laptop, as you mentioned above. The best battery for any laptop is the one which is the genuine battery of the laptop. You must purchase the genuine battery for Lenovo G460.
This battery is 6-Cell 4400mAH 11.1v. This battery will work fine with your laptop. Though there are some precautions for every battery. You have to use the battery carefully. Do not let the charger plug in the battery for the long time.
Just follow the instructions behind the seal of your battery.
I hope it help you in increasing the life of your laptop battery.
Thanks
