When I charge my smart phone completely or when I switch it one after some time, initially it performs fine but after some time it seems like my smart phone is not performing on optimum level. I have been experiencing low battery issues with iPhone 5 and it seems like battery is literally drained from my mobile. Is this due to overheating? How to get around this problem?
Battery Issues with Iphone 5
Overheating is the main culprit why a mobile phone easily drains its battery. And the only reason why your phone overheats is because of the applications that continuously run on your handset. Another reason why your phone overheats is when you are playing a game and this really makes your device hot and drains the battery fast.
There’s no problem if the reason why your battery drains easily is because you frequently play games. You can always charge the battery. But if you don’t regularly play mobile games and yet your battery drains fast, check your handset if there are apps that are not needed but are still running continuously.
This consumes battery because as it runs on your phone, the CPU process it continuously and if there are multiple apps running that are not needed therefore consumes more of your CPU and pulling out more power from the battery. It is actually not the phone that gets overheated. It is the battery.
The heat produced by the battery depends on the power consumption of all the components on your phone. If you only open 1 app, the CPU will only process few data therefore consuming less battery and no heat is produced.
The smart phone is always be heated for a little pressure on it. The ram of the smart phone plays an important role. If you are using many apps at a time on your smartphone the ram cannot cope with those pressures so the battery of the smart phone is getting lower. To avoid this problem you should use only one app at a time when it needed to work with. Or you can use some useful app which will help you to protect your battery level of your smart phone. You can use the Clean master, Du battery saver, Ram booster etc.
