I want to know the battery life of iPhone 4. My iPhone’s battery seems to last a little longer. I have been using the internet for about 15 minutes now and at the same time I was sending text messages using Siri and have checked my Facebook page a couple of times using 3G and Wi-Fi. Please tell me about how long is the normal battery life of iPhone 4. Thank you.
Jackman
Battery Life of iPhone 4
The battery life of any phone depends on the duty the phone performs, for example if play games, the heavier the performance the lesser the time it takes before recharging. The battery life of an iphone was tested and proved that even under very heavy performance can last more than 38 hours before it will require recharging. If it is not under heavy performance then this means it will last longer than the 38 hours. If under heavy performance then expect at least 38 hours before you need to recharge it. The longest it has been said that iphone can last is 4 hours.
lee hung
75 points
Hallo Martha,
The battery life of your iPhone can be as long as more than four days, it just depends on what tasks that you use it frequently use it for. For instance, you have been using for surfing and sending text messages and those are processes that consume a lot of power hence you will expect the charge not to last even more than a day.
But if you use your iphone for a task like making calls and receiving calls, then it may take even about four days before it ends since that is a process that will not lead to consumption of a lot of power. So if you want the power to last for long then minimize on activities that consume a lot of power like surfing the internet.
Hope this helps.
__
Regards
Lee Hung
