I need an accurate battery meter notebook monitor for my Dell xps with 2 GB RAM, 1 TB HDD and Windows 7 64 bit. I want a visual that indicates the voltage, percent, capacity and a countdown timer before shutdown . Anyone have this kind of monitor for Windows 7?
Battery meter notebook monitor for Dell
Hello, Michele Dow Lewis! Yes, you can choose a gadget of Battery Meter Version 2.2 for your Dell xps laptop. It's totally free gadget of 146.91 KB sized file. You can easily download it from http://addgadgets.com/battery_meter/ here. You can also use it in windows 7 compatible notebook. Have a lovely day!
Greetings! With Windows 7, there are a lot of gadgets for this type of task. You can search for them in Google and come up with numerous results. But if you want a very detailed battery meter, you could try this.
It gives accurate information on how long your battery will last and with a countdown. It is very light on system resources with only 700 Kilobytes in file size.
Not only that, the software has a lot of features a user is yet to know. Also display a graph-like below in its interface.
Hope this helps!
