I bought my phone a year ago. Till then its battery performance has reduced very much. The time for which the battery works has reduced by a large proportion. What should I do to fix this issue and also suggest the preventive measures for this?
Battery Performance Degradation In Mobile Phones
You can check the battery, whether it is damaged or is malfunctioning. It can be checked by just putting it on a plane surface, if the battery appears to have a curve, you need to go to your preferred shop and get the battery changed. You can further ensure that battery saver is not used that much as it instead consumes more battery. You are advised if you are a gamer, do not play games or use your phone while it is on charging.
