A beep sound on my computer
Hi Subroto.
It is a problem in your Ram.
There are two possibilities.
1. Your Ram has crashed. If so,then you have to change your Ram.
2. There might have some dust on your Ram.
So you have to open your Ram and clean it with a fresh paper.
Hope then your PC wont do this again.
Thanks for your question.
Feel free on Techyv.
If it’s beeping in the start of the computer. It shows that you have a problem with the ram, it might loosen or displaced from the slot.
You can easily fix it by following these steps.
Hi there,
This problem happens because of a loose connection in RAM. You can solve it by simply connecting the RAM a little tighter.
It would sound a little hard with a metal and a hard board. Then you will understand that those are connected well.
Only by this you can get your computer working.
But my suggestion is please clean both the RAM and the slot before connecting them.
Thank you,
Riley Weaver.
