Beeping Noise Issue Of PC
My personal computer started making a beeping noise this afternoon. The display wasn’t working, but the CPU was working fine with all the fans and lights functioning. What should I do?
You have a little problem with your RAM. Follow these simple steps-
• Try opening your cabinet and remove your RAM by opening the locks on the motherboard and pulling it out.
• Be careful while holding it. Clean the golden tip with an eraser and blow off any dirt on the RAM as well as on the motherboard.
• Re-install it and restart your system.
• If still the same problem continues, try doing the same with your graphics card (if installed.)
• If you don’t have a graphics card, then there is a problem with your monitor which can be fixed only be referring to a hardware expert.
For more information, refer to the pictures below.
1. Locating the RAM
2. How to clean it? You can also use a simple eraser.
3. Re-installing it.
Thank You.
