Beeping simultaneously problem with my PC
Posted on - 12/11/2011
Hi Guyz,
My problem is, When I switched on one of PC in my office,it started beeps a lot. I picked up its RAM as usually done and made clean.After putting it again the same beep was there.Then i replaced the RAM,But Processer didn't start. Power supply is well working then where is the problem.
Thanks
