Being A Gamer, I Face A 0x00003 Error Message
What is the 0x00003 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x00003 is an NVIDIA GeForce Experience error, and it is mainly seen in Windows 7, Windows 8, and Windows 10. The causes of the NVIDIA GeForce error message are as described below:
• Nvidia Telemetry is not permitted to interact with the desktop.
• Some Nvidia Services are not running.
• Corrupted Nvidia driver.
• Glitched network adapter.
• GPU driver interfered with the Windows update.
The ways to fix the error are below:
• Allowing Nvidia to interact with the desktop.
1. Hold Windows key + R to open the Run dialog box and type “services.MSC” and press Enter.
2. Go to the Properties which you will locate in the Nvidia Telemetry Container.
3. Select the Log On tab and make sure that the box is associated with Allow service to interact with desktop and click on Apply.
4. Go to the previous screen and click on Start.
• Reinstalling the Nvidia component.
• Resetting the network adapter.
1. Open Run dialog box and type cmd and press Ctrl + Shift + Enter to open an elevated command prompt.
2. Write “netsh winsock reset” in the command prompt and press Enter.
3. At last, restart your computer.
• Installing the latest Graphics driver.
• Creating the new Nvidia account.
Here is the snapshot of the error:
