Being A Gamer, I Faced 0xd0000225 Error
Examine the 0xd0000225 error? what is the cause of the error code and explain the methods to overcome this error message?
When the user reset the console and reconnecting but it comes up with the same error message “Give it another try” and then the error code 0xd0000225 which is apparently s Windows Xbox error code. 0xd0000225 error is an Xbox error that occurs when the user tries to boot up a game. The steps to fix the 0xd0000225 error code are as follows:
Step 1: Hold Windows Key+ R and type ‘Regedt32.exe’ in Run dialog box then press Enter to open the Registry editor.
Step 2: Navigate to the given location: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa
Step 3: Navigate and open the Security Packages.
Step 4: Put the value data as pku2u and livessp add to the data already existing. Click OK.
Reboot the system and try to boot again.
