Being A Software Developer, I Want A Detailed Description Of The Installation Of Dot Net Framework 4.5
Give a detailed description of the installation of dot net framework 4.5 and add the screenshot of the necessary steps.
Dot net framework 4.5 is a highly compatible and update of dot net framework 4.0. By using this dot net framework with visual basics, C# or F# programming language, you can write Windows apps.
A software execution and development environment designed by Microsoft and the various components of Microsoft.Net framework are as follows:
• Common Language Runtime.
• Base Class Library.
• Portable Class Library.
• Managed Extensible Framework.
• Dynamic Language Runtime.
• WinRT.
• Asp.Net.
• Windows Store Apps.
• Desktop Apps.
• Ado.Net.
• Silverlight.
• Windows Presentation Foundation.
• LINQ.
• Net Entity Framework.
• Parallel Extension.
• ASP.NET Web API.
• WCF.
• SignalR.
• Visual Studio 2012
The steps for installation of the dot net framework are as follows:
1. Go to the .NET installer executable and run it.
2. Accept the license and click on install.
3. .NET will be installed.
