Being An Employee, I Face 0x00003eb Printer Error Message
What is the 0x00003eb printer error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x00003eb printer error is a connectivity and installation error and it occurs mostly because of incorrect printer drivers. It should be checked that the printer driver should be matched with the printers.
The ways to fix 0x00003eb printer error are as follows:
• Check Windows Installer Service.
1. Hold Windows Key and press R to open the Run dialog box.
2. Type “services.MSC” and click on OK.
3. Now, a list will open. Locate Windows Installer and start them.
4. Restart your computer.
• Remove old drivers and re-install them.
1. Open “Devices & Printers”
2. Click on Print Server Properties from the top.
3. Locate the driver of your printer by clicking on the Drivers tab. Remove it.
• Delete the printer’s key.
Now, reinstall the driver and check it will work. The screenshot of the error is below:
