Being An Online Gamer, I Face A 0x000014c Error Message
What is the 0x000014c error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
When one or more system registry data is corrupt, and Windows encounters an error that is known as 0x000014c error. This error occurs in critical booting information is either corrupted or missing. The cause of the error are hard disk drive corruption, CPU problems, or the operating system is damaged.
The steps to fix the error are as follows:
• Run System File Check.
1. Open the command prompt and use the “SFC /scannow” command to check the files.
• Rebuild the BCD files.
1. Download Easy Recovery Essentials.
2. Burn the image.
3. Boot your system.
4. Once the application is running, choose the “Automated Repair” and click on continue.
5. Now a list of OS will come and you have to choose the drive which you are trying to repair.
6. Now the error will be located and destroyed by the application.
• Repair bad sectors in hard drive.
• Run the system in safe mode.
• Boot to good configuration.
1. Restart the system and press F8 repeatedly
2. Startup Option Screen will appear and select the last good configuration.
• Repair using Techutilities software.
