Mike Waall
10 points
Posted on - 03/29/2013
I just downloaded and installed the latest Windows 8 driver for my F5D8053 ver. 4 USB Network Adaptor but the USB adaptor in the device driver indicates a yellow triangle which means there is still a problem according to some advice. Is this Belkin f5d8053 v4 driver is compatible with windows 8?
Is this Belkin f5d8053 v4 driver is compatible with Windows 8?
Thank you for your question!
If you still have this alert, this should be a compatibility issue with the driver, to confirm that you have the most compatible driver, go to: https://www.touslesdrivers.com/, click “Mes drivers”, then, “lancer la detection”, it will install a plugin and scan your computer for driver compatibility and recommend the best driver if you do not have it.
