The benefit of creating forms with outlook 2010.
Programming languages provide for creating forms to capture data in very flexible ways from users. What is the benefit of creating forms with outlook 2010 over the alternative of doing the same in programming languages like visual basic or asp.net?
Answered By 5 points N/A #169388
Hi there,
Well, creating forms with outlook will give more flexibility in your program. As you know that VB is a programming language from Microsoft and so outlook. So they a gave a function in outlook to synchronize VBscript with it.So, you can manually add and delete anything you want by yourself including displaying the developer tab, form in design view, adding custom fields etc.
I hope the answer helped you.
Thank you.
