Hello, What makes Bitdefender Antivirus better than AVG Antivirus in this current days? Why should I choose Bitdefender over AVG from the technical point of view? Which of these two is ranked number one in the world? What makes Bitdefender special in terms of features and functions from other antiviruses? Thank you.
The Benefits of Bitdefender Antivirus over AVG Antivirus
Dear Garry B Graham,
Bit Defender and AVG both are popular security suites of current era. Bit Defender is more smarter than AVG , It takes less time in downloading and it has superior online surfing support than AVG. Sometimes AVG mentioned the important files as malware whereas bit defender is smart enough to tell which is malware and which is important file. Bit defender also include search advisor which looks like famous "Mcafee Site Advisor" and "Nortron safe Web" which tell at a glance the security level of any website / web page. Its firewall is also one of the best firewall while comparing with any other security suite. Furthermore Bit Defender provides better online support as it has online support forums, facebook page, twitter page, linkedin profile whereas AVG is lagging behind in this type of support and interaction with its customers.
Bit defender is unique than any other security suites that it has improved "smart scan technology" which didn't sacrifice the computer speed while scanning. It also adjusts the speed accordingly to optimize operation.
Bit defender is ranked higher on majority of reputed technical and software reviews website.
Bit Defender is better than AVG because of the following features:-
• Low downloading time of bit defendefer than AVG antivirus
• Clearly distinguish malware and other types
• It serve as search advisor to highlight the security level.
• Better social media services than AVG
• Bit Defender presents unique characteristics to smart scanning
• Low is downloading time of bit defender than AVG antivirus •
Clearly distinguish malware and other types •
It serves as search advisor to highlight the security level.
•Better social media services than AVG
