Please give me feedback on how Wireless Intrusion Prevention System (WIPS) works and please provide the benefits of having this on my wireless network. Because I heard that intruders can get into you backdoor without this kind of protection. Thank you.
lee hung
75 points
Benefits of WIPS (Wireless Intrusion Prevention System)
Hallo Pauline,
Wireless Intrusion Prevention System will help you protect your system from cyberpunk you might be having bad intentions of corrupting your information, tarnishing your name or just crushing your system so that you lose important information. The WIPs will reinforce the security of the system so that intruders cannot easily decipher the passwords and other mechanisms that you are using for the protection of the system and the data that is on it.
It makes it harder for the intruders to break into the system, and even if they may try harder, it will take them a very long amount of time before they find a clue and what that implies is that they will have given up.
Hope this helps.
__
Regards
Lee Hung
