BenQ large format display monitors
BenQ is now set to begin a large format display venture in the Indian market by unveiling 42 inch and 65 inch user interactive monitors.
What are the benefits of using LFD'S ?
LFD, Large format display has many advantages.
It has a large display of 1920 x 1080 p. Also come with the GPU and CPU Support.
But It is basically designed for commercial use considering the audience, as in board meetings, classrooms, announcements, and for the customers walking by your shop, Instead of very expensive projectors which costs a lot very difficult to handle. As you might have seen it in big shopping malls. That's why they are too expensive.
One thing is that it comes with multi options, as an HDMI support, TV tuner, etc.
The LFD Display is based on LCD technology (Liquid display). At the angles the image becomes invisible.
The LFD display is best for the graphic designers. No doubt you will have a very large display for that.
If you have a lot of graphics work like creating videos, etc., or want to use it in a meeting room etc.
Then you should go for this.
Samsung comes with some good models in LFDs
