Which is the best advance data recovery tool that will support in Windows XP and is available for free. I accidently formatted one of my drives, which I need to recover the data. Data are mostly of MS Excel (.xlsx) files. Please do the needful for suggesting me the best freely available advanced data recovery tool.
Best advance data recovery tool that will support in Windows XP
Hi Workman,
I believe I will be able to help you in as much as possible that you require. There are many types of the data recovery tools but I can give you the best according to my opinion since people's opinions are usually different.
The best advanced data recovery tool in my opinion is the 'Power data recovery free edition tool.' The tool is very efficient in that it only requires 128 Mb of ram in the system requirements and 100 Mb free space.
It is able to recover deleted data from recycle bin, restore lost data, even if partition is formatted or deleted, restore data from a corrupted hard disk, unexpected system shutdown or even system failure.
It also supports many types of hard disks such as the IDE, SATA, SCSI, USB, memory-card, USB flash disk.
It has five data recovery modules that can be used; undelete recovery, damage partition recovery, lost-partition, digital media recovery and CD and DVD recovery.
Yes you can easily recover your lost data by using recovery tools but here is a good suggestion for you that do not install or copy/paste new files because these files will overwrite the memory and you some part of data will never be recovered. So do not use your system till you get back your data. Here are some best recovery tools for you.
1. Test Disk -> Provides efficient recovery of lost or deleted data.
2. Recuva -> A data recovery tool supported on Windows, Linux and Mac Operating systems.
3. Photo Rec -> Powerful data recovery tool with easy GUI.
4. Restoration -> Recovers lost data, Windows supported.
5. Undeleted plus -> A commercial software which can recover your data in minutes.
Hey,
As per your requirement for the best data recovery tool that can support Windows XP. I am providing here with two links from which you can select one that suits you best. Both can support Windows XP.
I hope this will solve your issue.
Thanks & Regards.
Gillam Janetj
