Although it is very simple to use, I'm having trouble using HP Solution Center because I encountered some errors like "No HP devices have been detected". So, I decided to use an alternative for HP Solution Center. Any ideas? Where can I get it? Can you give me its edge compared to HP Solution Center? Thanks.
Best alternative for HP Solution Center
Hello Eleni Hughes
Hope that my message finds you well.
For solving the error "No HP Devices Detected. HP Solution Center Will Close Now" message You can follow this link:
http://hpanswers.blogspot.in/2007/12/no-hp-devices-detected-hp-solution.html
There is also a video for this common issue you can watch it.
I think if you followed the upper link your problem will be solved.
Hope this solution will help you and please let me know if you need anything else.
Kind regards,
