I am having Samsung mobile and got Samsung PC Studio 3 in my system in order to manage the files in my Phone, but it seems to have a few technical issues. I need to manage the files in my Samsung mobile phone, So please suggest me the best alternative to PC Studio 3 of Samsung.
Best alternative to PC Studio 3 of Samsung
Hello John D Armstrong,
Following are the alternative ways to manage files in Samsung mobile phones:-
Samsung has the software called Samsung Kies.
Samsung Kies software is used to manage the latest manufactured mobile phones
It is a free software you can download
Before downloading please check the list of compatible mobile models with Samsung Kies
There is a another way to manage the files in Samsung mobile phones
Go to your mobile phone setting à Connection setting or USB setting (depend on mobile model)
Select “Ask on connection” option
So when next time you connect your mobile to system through USB cable it will prompt on the mobile screen to select an option.
Select “Mass Storage”
The system will automatically install the required USB drivers (If you are connecting first time through this mode)
After installation it will create the removable drive in your system’s My Computer.
Just double click on drive and open. You are ready to manage your files in mobile phone.
Thanks,
Alisha B Stone
