Best And Affordable Windows Server 2012 Anti-virus
I am looking for best and cheap windows server 2012 anti-virus. Please throw some light on this matter and tell me which one is best suited.
A good number of consumers AV make also have venture editions for utilizing on servers. Microsoft’s version is at the present element of system center 2012 and is called endpoint protection, and it is essentially MSSE with additional design options (like to manage schedules and prohibit types of files or locations which can be dangerous on servers), In my opinion I’ve found SCEP price effectual if you have a lot of VMs on a corporeal server, or else it’s just a case of trawling approximately a variety of suppliers and inspecting their price per install.
If you are looking for an antivirus program for your Windows Server 2012, try using any of the following security programs from ESET.
Another security application aside from ESET products is Norton Security Deluxe. This is the combination of Norton Antivirus and Norton Internet Security all rolled into one power security software.
