Best and free Desktop Notes for XP
Which is the best and free Desktop Notes for XP, Which will have Reminders, Auto Pop-up options including Snoozing and Dismissing Alarms.
Hello there,
There are so many software available online but many of them are very expensive. Well I would suggest you to download Code Amber Alert Desktop Ticker 1.1. It is available free of cost. You can download it from the below given link- http://download.sharewarecentral.com/95/18694/code-amber-amber-alert-desktop-ticker.html
Hope it helps!
Cheers
I wasn’t able to find sticky notes or desktop notes that feature alarms or somewhat similar but I’ll list below some of the sticky notes I managed to find that works on Windows XP.
Notifications
