The Best and most downloaded desktop appointment calendar Windows 7
Is there any software or application to keep a track of meetings and appointments? I want to keep it handy and visible on my screen. Please specify any desktop appointment calendar Windows 7.
Answered By 10 points N/A #177889
The best suitable calendar for the purpose of keeping track of appointments, meetings and upcoming events is Interactive Calendar. It blends with your desktop wallpaper so well that you won’t distract from your work. It is highly customizable.
The only disadvantage is that it doesn’t sync with other calendars like Outlook Calendar, Google Calendar, etc. and it does not have Alarm support. However, you can always import and export data in various file formats such as CSV, XML, TXT, etc. You can download the software for your Windows 7 PC from interactive-calendar.en.softonic.com
