The Best Android App For Soil Science
Which Android app could be selected as the best app so far for testing and detecting the soil nature and the soil composition? I am in great need of an Android app which can assist me in my day to day soil test and analysis. I will be very happy if you can help me find or lead me to the best application that best fit this job and please do not forget to enlighten me on your choice or suggested app. I would also want you to give me a detailed steps about its usage. Thank you.
Answered By 590495 points N/A #151901
If you are looking for an Android application for testing soil, try Soil Test Pro. It is a 2-part system, the Web Headquarters installed on your computer and the Soil Test Pro application installed on your Smartphone or tablet. These 2 applications synchronize together so that you have all the information whenever you need it. When you’re in the field using your mobile device either a Smartphone or a tablet, you can work even if you don’t have a cellular service.
Using the GPS, you can draw or sketch field boundaries. For better visibility when working in sunlight, you can use high contrast views. You can also set any grid size. Sampling can be simplified using GPS-located bag numbers. When you’re not in the field and you are using your computer, you can use Soil Test Pro Web Headquarters to draw or sketch field boundaries through aerial imagery.
You can put in limitless farms and fields. You can print shipping sheets so you can send samples to your desired lab. You can obtain fast test results within 5 to 7 days. You can view and print your field maps through aerial imagery. You can download the app from Soil Test Pro Google Download.
