Hi Friends,
Which is the best Android CAD application sources that will help to create, modify & analyze technical drawings. I would like to have a free app for Android that will help me to make modifications in the DWG drawings both 2D and 3D. Please Suggest.
Thanks & Regards,
Bernard L Jefferson
Best Android CAD application sources
Hello Bernard L Jefferson,
AutoCAD apps help you draw and manage your difficult diagrams, models, designs, and much more. There are many AutoCAD apps for the Android platform. I think the AudtoCAD WS is the best out of all of these apps.
You can use it to edit and share your AutoCAD design anywhere in the world. You can easily open DWG, DWF, DXF, and many more files. You can also open 2D and 3D DWG drawings.
Download them here.
You can also download other AutoCAD apps for your Android here.
One of the best Android CAD application that I have found so far is AutoCAD WS for android.It should help you to make drawings and make modifications to 2D and 3D plans.
It is a really powerful tool which will help you in whatever work you are doing.
I have included a link where you can download it on Google Play.
If you are looking for CAD applications for mobile phones or Android phones, try downloading DWG FastView on the Google Play store. It is a cross-platform CAD application that is completely compatible with DWG and DXF. Among its features include:
- Edit
- View
- Measure
- Dimension
- Find text
It allows you to do real CAD work while on the go. The latest version at the moment, DWG FastView 3.7.9, requires Android 4.1 Jelly Bean and higher. This app is rated 3+. Another app you can try on Android is AutoCAD. This is the Android version of AutoCAD from Autodesk. For iOS users, you can try AutoCAD on the Apple App Store.
This is the iOS version of AutoCAD from Autodesk. The latest version at the moment requires iOS 11 and higher and works on iPhone, iPad, and iPod touch. This app is rated 4+. Another one for iOS is Shapr 3D CAD modeling. The latest version at the moment requires iOS 12 and higher and works on iPad only.
This app is rated 17+.
