jcato
40 points
Posted on - 04/13/2012
Hello there TechyV…!
I wanted to install an AntiVirus for my PC today but Im not quite sure what should I install.
I need your opinions on this guys.
I wanted to have an AntiVirus that is reliable but for free only and it should be supported in Windows XP.
What anti virus should I install on my PC and where can I download it?
Thank you.
Best Anti Virus for Windows XP
I will suggest Avira Free Antivirus 12. It merges quick scan with more than the usual protection for a complete security combination.
Installation:
Download Avira. The version 12 presents a two-click installation process. This process is part of the "less is more" scheme, wherein it gives a consistent level of protection like before without issues. The other click will direct you to the Ask.com search engine and toolbar. The Avira's WebGuard function is powered by the Ask.com and is included on the toolbar. You will also be asked to make the Ask.com as your default search engine. When the installation is done, Avira will perform a quick scan which will take about 1 minute and 25 seconds to complete.
Hi Jcato,
In the year 2012, we can’t tell what kind of increasing and malicious viruses, Trojan threats, Malwares and worms will be set free over the web which can possibly put our computer and laptop systems at danger and risk whether they are intended for personal or office work computers.
Many cyberpunk all over the world are continuously producing and creating new and more destructive viruses to damage your computer data’s .Under such conditions, I required for you to have remarkable antivirus software that is capable of deleting and removing all these newest virus and irritating spyware programs.
I recommended to download and install the avg antivirus 2012 which supported in Window XP.
You can download it here at softonic.Â
Hope this will help you.
Stanislava Yap
Hi. The best anti-virus for Windows XP is Microsoft Security Essentials. You can download it here:Â https://support.microsoft.com/en-us/help/14210/security-essentials-download
Here are the benefits and features.
It's free.
Microsoft Security Essentials is a excellent class of antivirus protection.
By means of real-time protection such as quick scan, full scan and custom scan, you can easily recognize threats before they even become a computer trouble.
It automatically suggest recommended action for all the threats detected.
It has firewall on the go.
It has database which describes the characteristics and behaviours for known malware.
I hope that this solution will help you choose which antivirus will you install for your computer.
