I have bought a new pc, also thinking of connecting it to an active internet connection. So I would like to keep my pc safe from malware, is there any way you can help me in choosing the best antivirus at the market right now?
Best Antivirus Software For Pc
Hello, it is a good decision of installing an antivirus into a PC, but before downloading any random antivirus, it is important to research for a reliable brand because you might end up installing a virus or a malware instead. So be careful before doing anything. After searching for an antivirus for my PC, I ended up with Bitdefender.
But there a lot of software that gives you safe browsing function as well as a decent user interface.
I chose Bitdefender because of the fact of its minimal ram consumption, and it took only a small part of my screen. But if you think that you need some more options then you can also go with the ones I have listed down below:
*Avast:
This is one of the best antivirus software considering the price and also the user experience. Its real-time shield, and also the smart scan option is given it a newer dimension in terms of normal usage. It is one of the oldest and trusted software in the business right now. But a bit expensive than Bitdefender.
*McAffe:
It is fantastic considering the price and the specs it offers. This software has features similar to Avast, but this one has a better impact on system performance. My friend has this software, and it worked fine for him. But for me it was a bit expensive, so I went with Bitdefender.
*Kaspersky:
It gives a lot of quality features but to its users. It is a bit on the pricier side than the other counterpart. But it offers awful a lot of specs than the other software.
So it’s all up to you to decide.
