Best antivirus for windows 7 ultimate
Can you explain which antivirus is best for Windows 7 ultimate version? May I get some name and feature of those antivirus? I face a lot of problems on my computer.
Hi Rokan,Â
I believe I can be able to help you solve the problem since it is easily solvable. The best anti-virus software I would advise for this kind of Windows system (the Windows 7 ultimate) is the Kaspersky anti-virus. This is because Kaspersky has full protection, provides ample safety against the Operating System as well as internet browser intrusions, keyloggers, harmful pieces of software.
It also offers web defense through plug ins and it is also very effective in fighting against viruses especially the modern ones.
It is also very easy to install and make it running on your PC just as long as you have the installer and, of course the key unless a trial version. This is the process you follow to install it;
Ensure to close all running applications and also ensure there is no incompatible software for the anti-virus.
Run the installer and follow all the prompts to install.
Once the software is installed, go the 'Settings' options and activate if you have the keys to enable all functionalities.
Restart your computers for the new effects to take place.
I hope this solves your query.
