Best app for mass SMS iPad 2?
Which is the best app which facilitates mass SMS iPad 2. Also what are the average charges for a paid mass SMS service?
There are many apps available in the app store for sending SMS in iPad2. To send bulk SMS you need to download the apps that support sending bulk SMS and they are not the same as the apps that send single SMS. You can search the app store by typing the keywords "bulk SMS" in the search bar.Â
The charges of the SMS may vary according to your service provider. Check with your service provider to find out about the charges for each bulk SMS. A few popular apps to send bulk SMS are:
1. Bulk SMS – You can get it here. It is a widely used app to send bulk SMS. See the screenshot below:
2. Simple SMS – You can get it here – http://holman.id.au/apps/simplesms/index.html. See the screenshot below:
