Best Audio playback technology for iPhone
Which audio playback technology do I need for this?
Thanks in advance.
Answered By 0 points N/A #89404
These are the best audio playback that I found:
Audio Queue Services
This service is for recording and the playback processes. It is installed into the iPhone operating system. It allows you to play a wide area of file types in the iPhone. To play some music you have to install the codec to your operating system manually.
AVAudioPlayer
This is another player. This player allows you to play audio files that you have in your memory. You can use this player to play more than one music file at the same time. This player will also support long clips. And also it has a lot of tuning and settings to increase the quality of the music.
I hope this will help to you.
Thank you.
