Best Backup Solution and Best Location to Perform a Backup
Backing up of any data that is important is always important step for better career of a developer or for a computer user but most of the time we don’t understand what is the best time to backup your files and where to back up your files.
The terms “when” depends on you. If you think it is time to backup your important files it is the time to back up though it not always understood before you lose it. Now the terms ‘where’ depends on your data size if it is less than 4 gigabyte you can use DVD disk to store it.
If it is huge like 100 gigabyte then it is wise to back up it in a external hard disk. Do not store data in the same physical drive. You can also store data in internet domain though it takes so much time.
You can back up the data on your computer on various storage medias, and some of them include the following:
But what I consider to be the best backup media for your data are the external hard drives and the storage on another computer or the same computer. The external hard drives have a large space and therefore will enable you to back up a lot of files compared to flash drives and DVD drives.
They are also not vulnerable to corruption as are the DVDs. As for storing on another computer all you need to is get the data and store it in a partition that is not the primary hard drive partition on the other computer. You can also back up the data on the same computer but on a different partition.
Clair Charles.
There are thing for you to consider when having a backup system Consider you Backup Options, Do you want a backup only your important files? You can buy a flash drive for it. But if you want a complete backup with your music programs and files I recommend you to buy an external drive.
But before buying you want to consider 2 things on the product first one is the data compression and the second one is password protection and encryption we all want our files to have a maximum storage while it is protected and safe from the people who wants to get our files or see it.
