Hi there,
I am looking for a simple camcorder for my wife. Basically, it will be for taking clips of our daughter. She's not a techie, so simple will be best. If the camcorder is lightweight, and has a simple way to transfer files that would be amazing.
Thanks for all your help.
Best camcorder for my wife
Hy,
You are looking for a simple, and portable camcorder to buy. Everybody likes HD video with proper quality and resolution, but our mobile phone can not give HD quality image or video. I can share with you about a simple but feature able camcorder.
Panasonic HD camcorder
HD camcorder can capture 1920 x 1010 HD video. There have fully automated system for operate. Broadcast quality videos are changeable and price is not so expensive. You may choose it for you new camcorder. The price of this camcorder is only £500.
Hope it will help you to buy a new camcorder.
Thanks
If you want a simple camcorder with fewer frills, you can check Flip Video Camera – It’s basically lightweight, sleek and portable (Dimensions 2.2 x 1.2 x 4.2 inches, 8.8 ounces). It has a simple user interface – a four way control that doesn’t take much to figure. It has a built in USB connector which gives you the convenience to plug the camcorder directly to the PC. Also, you don’t need to download or install photo sharing software – as there is already pre-loaded FilpShare software. All you have to do is press the red button to start capturing photos and videos (2 hours of video) which has a surprisingly good quality for a low priced camera.
