alwyn white
20 points
Posted on - 04/13/2012
I'm using ASP.NET for my website. I'm confused whether to get a free Content Management System for my site or pay for it. What CMS would you suggest for ASP.NET blogs? Can you provide me a list of free and paid CMS and the advantage and disadvantage of using such CMS?
Best CMS for ASP.NET Blogs
I suggest following CMS.
1. DotNetNuke
2. MojoPortal
3. Kentico
4. Umbraco
5. Orchard
6. Sitefinity
7. Composite C1.
The above CMS options are very good choices. Please try it.
Free CMS: Â Â
CushyCMS, JoomlaDrupal, MODx, WordPress.
Paid CMS:
Interspire, Alastrasoft, Softbiz, ExpressionEngine, AssetNow NX.
Advantage of CMS:   It allows editor interact with site. Graphical user interface is provided by CMS. Using this graphical user interface editor can create content schedules, multimedia files. Graphical user interface also allow editor to add image. It gives decentralized maintain. You don't need HTML knowledge. Word processing create content directly. It is also designed for non technical authors. Based on database content menus are automatically generated.
Disadvantage of CMS: Â Â Â CMS provide limited template to design.
