The best database/versioning system of Google document
If Google document is to be used like an app., which database/versioning system will be the best? How can we use Monogodb Cluster to manage 20K+ simultaneous links?
If you are using Google document and want to store data in a database then Google has its own database. And it is the best option to use Google’s default database as an ultimate database in your pc. There is nothing better like that. And it is also highly squired. So there is nothing to worry about it. In this case database/versioning system will be the best.
Run Monogodb Cluster in your pc. It will take time to recollect hardware information from your pc. Now reconfigure it as you wanted to use in your method. After that you will have option to manage 20K+ simultaneous links.
