Hi ! I am looking for building a very simple database for chrome questions answers.
The front end can be VB or MS access forms.
For back end I am little bit confused as which database package to be used.
My requirement is easy to use interface and more flexible to customization.
Can you suggest the best one?
Best db package for chrome questions answers for kids?
In Oracle, packages encapsulate related procedures, functions, and associated cursors and variables together as a unit in the database. Packages usually have two parts, a specification and a body. The specification is the interface to your applications; it declares the types, variables, constants, exceptions, cursors, and subprograms available for use. The body fully defines cursors and subprograms, and so implements the specification.
The packages provide advantages in the following areas:
Encapsulationof related procedures and variables in a single named, stored unit in the database. This provides for better organization during the development process and makes privilege management easier.
Separationof public and private procedures, variables, constants, and cursors.
Improved performance since the entire package is loaded into memory when an object of the package calls for the first time.
You can generate and reverse engineer database packages in the same way as other database objects. When you reverse engineer a database package, the sub-objects (variable, procedure, cursor, exception, and type) are created from the specification and the body of the database package.
Creating a Database Package
You can create a database package in any of the following ways:
Select Model > Database Packages to access the List of Database Packages, and click the Add a Row tool.
Right-click the model (or a package) in the Browser, and select New > Database Package.
Database Package Properties
To view or edit a database package's property, double-click its Browser or list entry. The property sheet tabs and fields listed here are those available by default, before any customization of the interface by you or an administrator.
The General tab contains the following properties:
Property
Description
Name/Code/Comment
Identify the object. The name should clearly convey the object's purpose to non-technical users, while the code, which is used for generating code or scripts, may be abbreviated, and should not normally include spaces. You can optionally add a comment to provide more detailed information about the object. By default the code is generated from the name by applying the naming conventions specified in the model options. To decouple name-code synchronization, click to release the = button to the right of the Code field.
Stereotype
Extends the semantics of the object. You can enter a stereotype directly in this field, or add stereotypes to the list by specifying them in an extension file.
Owner
Specifies the name of the database package owner, which you choose from the list of users.
Privilege
Lets you specify whether the functions and procedures in the database package execute with the privileges and in the schema of the user who owns it (definer), or with the privileges and in the schema of CURRENT_USER (invoker).
Table
Specifies the table with which the database package is associated.
Template
Specifies the template on which the database package is based. If you use a template, then the remaining tabs of the property sheet will be completed by the template. If you make any modifications to the other tabs, then the User-Defined button to the right of the field is depressed and the package is detached from the template and will no longer be automatically updated when you modify the definition of the table with which it is associated.
Keywords
Provide a way of loosely grouping objects through tagging. To enter multiple keywords, separate them with commas.
Wish you all the best.
