Hello!
I would like to purchase a new laptop and sell the old one. I want to know something about Gigabyte P37X v3. What are its specifications? How much is it? Is it bundled with any multimedia software or games? Is it advisable to buy this laptop? Is there any review the guarantees that this is the best laptop to be used by gaming enthusiasts? What are the peripherals included in this? What are the ports available for this laptop?
The Best Designed Laptop for Game-Enthusiasts and Fanatics
Gigabyte P37X v3 is quite a great laptop that comes with awesome hardware configuration with extensive enhancements and is quite compatible for heavy gaming.
This laptop comes with Intel Core i7-4720HQ processor that can be turbo-boosted up to 3.6GHz. It’s also integrated with NVIDIA GeForce GTX 980M GPU with 8GB GDDR5 graphics memory. This specification makes this laptop quite compatible with all types of modern games. NVIDIA GeForce GPUs are able to be used as a general CPU, so speed will be superb, no doubt.
It has double port for RAM, each supports DDR3L RAM with 1600MHz bus speed and can be expanded up to 16GB. It’s quite good for gaming and for heavy usage as well.
After judging all the specifications, this laptop can be an ideal laptop for gaming. You can find its full specification here.
