hannahwtc
10 points
Posted on - 06/09/2012
I have trying to look for Desktop PC casings available in the market and my sources are limited. I could not find one that I like best. Any suggestions? I want one that would have enough fan rooms as the PC will be used primarily for gaming.
Best Desktop casing available now
Hi, I agree with you CPU casings are really important when it comes to Gaming and 3D jobs. Anyway if you are looking for a good CPU case you can visit these websites.
http://www.xoxide.com/
https://www.newegg.com/Common/CommonReCaptchaValidate.aspx?referer=http%3A%2F%2Fwww.newegg.com%2FComputer-Cases%2FCategory%2FID-9&why=8
They offer a variety of selections for CPU casings depending on your need. There are even CPU casings that comes with free fans. Others have thermal insulators inside. There are even CPUs with water cooling systems. All these are great for gaming enthusiasts. I would also suggest that you get a very good kind of power supply which can last longer compared to the ordinary one. You can easily get the power supply at your local computer stores.
