Best Desktop Specs for Gaming
I want to play one of the latest games like "Dirt 360" but my desktop can't support it.
What specs can you suggest for me to play that kind of game.
I only have $450 – $500 budget to buy new specs.
Hope you help me guys!
Best Answer by Rennier Lean
Answered By 0 points N/A #115327
“Dirt 360” minimum system requirements and specs.
Intel Core CPU –  Core 2 Duo E7400 2.80 Ghz    at around  $113.00
For AMD CPU – Phenom II X2 555 Black Edition at around  $99 USD …
Nvidia GFX Card – GEForce GTS 240 –  at around $99.00
ATI GFX Card – Radeon HD 5670 512 – at around $85
RAM Memory  should be  3GB
Hard Disk SPACE also should be 15 GB
And Direct X  – v.9
These are the recommended requirements as listed that you need to require in order that the game will run constantly in good frame rate with the max. graphical features and large resolution
Answered By 590495 points N/A #115329
If you are a gamer, you need to have a high quality and specifications.
This is important for gaming because the brightness, clear and enhanced graphic will play big factor to the game itself.
Here are my suggestions of specifications, hardware, software and other accessories needed.
Processor – Intel Core i7TM 2600 k Processor
Hard Disk – 160 GB Intel Solid State HD
VGA Cards – 1.536 GB Nvidia GeForce GTX 580 384 bit DDR5
Operating System – Windows 7 Professional
LCD 22 inches ACER Ferrari F 22 Monitor
Web Camera – A4tech Webcam PK 635
These components are a bit expensive, but it's worth it of having these parts.
