Best effective memory repair tool
Hello Techyv Friends,
I would like to have a suggestion from techyv experts about the memory repair tool. Please do the needful for advising me the best effective memory repair tool and  how to repair the RAM using the same. Waiting to hear from experts.
Thanks & Regards,
April Rosas
Answered By 5 points N/A #151351
Hello Aril Rosas,
Firstly you can check your memory by Windows Diagnostic Tools. For this, type mdsched.exe (start menu), then press enter, a pop up window will appear with two option, go with recommended option.
Your computer will take reset and diagnostic begins.
Another option you have, an advanced memory diagnostic tool named as memtest86.
You can do checking after downloading your compatible version.
Hope this would help
