Best File Mangers for an Android?
What are the best Android app’s to File manage. I want some File management App’s and the best out of each APP
Since you are looking for the best file managers for the Android handsets, here are several you can try:
Root Browser – this Android file manager is dedicated on browsing the entire phone system. This is the browser recommended for people or for users who have root access. It works as the usual file browser but with added features like tools that can be used with compressed files, for applying theme, and the capacity to handle and edit files. It requires Android 1.6 and higher.
File Manager [Explorer] – they refer this browser as highly rated and highly capable file manager. It has the usual standard features plus added features intended for advanced users like FTP support, media streaming, LAN support, and cloud storage support. The application doesn’t have the best look but it has the more advanced features and it’s easy to use that’s why it is recommended for both advanced and novice users. It requires Android 1.6 and later.
File Manager – among the 3, this file manager is the app optimized for Android tablets. It uses the Holo theme so I’m sure Holo fans will love it. You can change the color of the theme from light to dark. Besides the usual features of a standard file browser it only has few advanced features. It is also integrated with an image gallery. This application requires Android 2.2 and later.
The apps on leader board of Google play are ES File Explorer and Astro File Manager with Clouds. Both of these apps provide access to all the cloud storage like DropBox, SkyDrive, Google Drive and social media, Facebook and Twitter. They have a friendly and easy interface where you can access and browse your phone easily.
Notifications
