Best Five Basic and Cost effective 3G mobiles in Micromax
Hello Friends,
I am planning to buy a 3G mobile in Micromax, Please suggest me the best five basic and cost effective 3G mobiles in Micromax or any other brand. I just need any basic model having 3G support, which will be cost effective, Please guide me through your suggestions.
Thanks and Regards,
George Saunders
Best Answer by Stark P Blake
Answered By 5 points N/A #198833
If you want to buy any Micromax, cost effective 3G mobile you can go for any of the below phones. Among these smartphones Micromax A89 Ninja is the recently launched mobile. You can check the link for detailed specification.
  1. Micromax A89 Ninja
  2. Micromax A110 Canvas 2
  3. Micomax A100
  4. Micromax A101
  5. Micromax A90s
Other than Micromax you can look into Karbon K65 Buzz or Karbon A9.
Ccharle William
Answered By 0 points N/A #143983
Hello George,
Micromax offers a wide range of 3G mobile phones in affordable price. I think you can easily choose anyone from there within your budget that can fulfill your requirement. Among all available offers I think the following sets can meet all of your requirements.
  1. Micromax Superfone A50 Ninja
  2. Micromax A54 Smarty 3.5
  3. Micromax Bolt A51
  4. Micromax Q80
  5. Micromax X650
If you want to use other brands’ model with similar types of features then you can go with Samsung Champ Deluxe, Samsung Chat, Nokia C2-03, Karbonn K1616 Magic.
Here is the outlook of all models.
Answered By 0 points N/A #143984
1. Micromax Canvas 3D A115
    A 5 inch Smartphone on which you can view 3D content…
2. Micromax Canvas Viva A72
    A dual SIM Android Smartphone with a 5-inch display, 1GHz…
3. Micromax Funbook Talk P360
    A 7-inch tablet with voice calling support with 1GHz…
4. Micromax Bolt A51
    A 3.5 inch touch screen phone loaded with Android 2.3.7…
5. Micromax Bolt A35
    A dual sim 3G enabled touch screen smartphone with 2 MP…
