g.k.sumon
250 points
Posted on - 07/20/2016
Hi people,
I own a Samsung Galaxy J5 and it has a SPlanner installed in it, which is the default Calendar Application of the phone. I want to install the Best Free Calendar App for Android Phone that has more features than the default application.
The Best Free Calendar App For Android Phone To Default Calendar.
When it comes to the best, Google tops the list almost every time. Such is the case with Mobile Calendars. Google Calendar is an application that comes with many additional features that SPlanner cannot provide.
The layout and interface will seem to be familiar to you if you have used Google Calendar on your Computer. You can choose the Dates, Months, and the Agenda view to see the relevant information in a concise manner.
You can synchronize your Calendar on the Web as well. This helps you in generating the list of upcoming events related to you, in every device you want to make.
