Best free check SD speed tool on the market
Asked By 190 points N/A Posted on -
Hi there,
I'm hoping that someone can point me in the right direction for the best free check SD speed tool for an Android device?
Either that or if anyone can recommend a review website where I can compare these tools myself.
Thanks in advance.
Best Answer by Eastern Carl
Answered By 5 points N/A #163514
Through SD tools for your android, you can test the speed of its reading and writing.
You can view detailed information of your SD card, which also includes whether your card is fake or real.
The following is a website through which you can download a SD speed tool for your android device:
You can view the complete details of your android device through download the app from the following website:
Answered By 0 points N/A #163515
SD tool for android is free and used to test the speed of your SD card for android applications. Kindly, go to the link and you will get a lot of information about SD tools for android.
https://www.addictivetips.com/mobile/test-read-write-speeds-of-your-android-device-sd-card/
 You can also download it from the link given below by clicking at the Download SD tools. The application is a freeware.
https://play.google.com/store/apps/details?id=ales.veluscek.sdtools
JK
