Hello experts, I am using Windows 7 and I would like to know if there is software that can detect and monitor the temperature of a CPU. I need to have PC temperature software so that I can decide whether to buy a cooler or not. Please give me an idea. Where can I download this software? Thanks.
Best free Computer Temperature Monitoring Software for Windows 7
"Real Temperature monitor" is a tool which keeps us updated about temperature of CPU. Â Many other tools are also available. If your PC gives a problem of heating then you may need to change the position of your CPU. Place it where there is enough crossing of air. An additional fan is good for CPU.Â
Hi Marsh,
Core Temp is an easy to use, friendly and helpful software that lets you see the temperature of your processors. It also displays information about the model number of your processor and also displays temperature separately for each core in your processor. This is the main USP of the software.
You can download the software using the link given below.
Link: http://www.alcpu.com/CoreTemp/
Screenshot:
Hope this helps!
Drianna allen
