Best Free Graphic Design Software for Windows PC
Hello i am just trying to find out that which is the graphic design software best for pc? Any one can help me Thank you
Hi Nicholas,
Thanks for sharing your problem. There are a lot of graphic design softwares out there but the most used and popular is the Adobe Photoshop. They have their newest product CS6 which has more editing functions, new creative functions and  its equipped with adobe mercury graphics. Check it out here http://www.adobe.com/products/photoshop.html
Hi Nicholas Calderon,
There are two kinds of graphic: vector graphic and raster graphic. Each kind has its own functions and has own group of software to design.
For example, if you want to create brochure, logo or name card, you should use vector graphic. If you want to editing, retouching your photo, you should use raster graphic.
Some software for vector graphic: Corel Draw, Illustrator, Inkscape
Some software for raster graphic: Corel Photo Paint, Photoshop, GIMP
If you want something free, I suggest Inkscape and GIMP
Hope this helps
Hi dear,
Thanks for sharing your problem with us.
This world is highly introspective and artistic. There is race of graphical innovations in this world.
Everyone wants to set himself or his industry on the top for graphical interfaces. Today, as we see, there is a lot of advertisements every where. These advertisements will impress the customer very much if these are well designed and make a cooperative environment.
The most modern uses illustration and graphic design software to create their logos, advertisement and other graphic things like animations, cartoons etc.
You should choose those graphic designers which can make very easy interface among you and graphic software.
It means that graphic designing software in which you can easily do your work. Where no more complications.
And that software which provides all the facilities about digital imaging features.
Choose that one which provides print layout features and help and support.
So that you can easily work with and can make creative designs.
Here i am going to tell you the most powerful and most useful graphic designer software in this regard.
You should choose "Adobe Photo shop" and "Corel Draw" and "Adobe illustrator" because these are the kings of this era in designing or web designing.
Thanks i hope this will help you to achieve your goals.Â
